D-44 S11 rear axle bearing's?
jeff campbell
Active member
I know I just asked this ? But whats the difference in the bower a-10 bearing set,versus the tk-set 10? $10 extra for the timken name? They're both usa bearing's?thx-Jeff well I just got my new wheel bearing.the ( timken ?) skf/ napa-br 10,is made in japan-$49.99../ the national a-10 I got from advance auto parts is made in china-$39.99.the skf came packed w/grease,the national didn't.the skf is labeled as a "pinion bearing"..they both have the locking collars & are the same exact dimension's.I can't see any visual difference's in either bearing.so,I'll put 1 on each axle..only reason I got the national was cause they had it in stock.I wanted to compare the 2 bearing's.I also got the national # 9912 wheel seal's.any thought's or remark's are welcome,thx-Jeff
To have the timken's,and they were 1/2 price,got 4 of the 9912 national seal's also for $6 ea.instead of $17 ea. 2 timken's for the price of 1 napa bearing.saving's to put elsewhere. 2 seal's for the other Scout.Jeff
