LutzCoyote
Good Evening,
I have a 72 Scout II with a 304 motor and have noticed what seems some like some lack of power. In doing some checking I get spark to all the plugs but while running If I pull a plug wire from the even cylinders, I notice the running engine changes which I would expect however, if I pull the plug wire from any of the odd cylinders there's no change to the engine. Does this mean those cylinders aren't firing because i'm not getting fuel, a valve or cam bearing issue?
Just as a FYI, I replaced the plugs and still have the same result.
Thanks In advance for any suggestions of if there's any additional information I can provide.
Sam
Sam
