Cracked frame at body mount
Craig
Active member
The frame cracked by the body mount under the door hinge.
It's pretty bad being crack from the top to the bottom. See pic.
The plan is to clean it up and inspect the damage.
Next I will cut the body mount loose from the frame, leaving the top tab welded to the frame. The plan is to add some steel to the side of the frame
