CPT Reverse Shackle Kits ON SALE!!!!!!
ihpartsjeff
Administrator & Owner
Staff member
For the month of May all CPT reverse shackle kits are on sale for $240(regular price $289.95). We have plenty of kits in stock and ready to ship.
IH Parts America: CPT Scout II reverse shackle kit w/ 5" shackle
IH Parts America: CPT Scout II reverse shackle kit w/ 6" shackle
These kits will work with either spring under or spring over vehicles on all 72'-80' Scout II's, terra, and traveler. Improved ride quality. For mild to wild rigs this kit does them all. Kit can be modified for use on Scout 80/800's. New 2.5" wide version coming soon for those of you running wider than stock leafsprings.
Mechanos
Cool... I'm just about at the point where I need one of these kits. Actually, though, I need 2.5" version... Can you estimate just what "soon" means? I guess I could always split the 2" hangers down the middle and weld a strap over the gap. I just need to figure out if I want to go with 5" or 6". I'm leaning toward 5" at this time.
ihpartsjeff
Staff member
cool... I'm just about at the point where I need one of these kits. Actually, though, I need 2.5" version... Can you estimate just what "soon" means? I guess I could always split the 2" hangers down the middle and weld a strap over the gap. I just need to figure out if I want to go with 5" or 6". I'm leaning toward 5" at this time.
Around here soon could be anywhere from tomorrow to a year but if you need a set right now I can modify a set for you or you can modify an existing set. Give me a call when you are ready and I'll set you up with a custom kit or at least the provisions to modify the kit for your personal needs.
ihpartschad
IHPA General Manager
I know this is very basic but I am going to bless you with my knowledge anyway. The way I did mine and it worked perfect is I cut the middle out of the brackets so that there were 2 side pieces, then clamped a 2 1/2" strap inbetween the two sides, welded it in and ended up with a perfect it.
Mechanos
That's pretty much what I was talking about.... Would be simple enough. The other thing I'd like to address is the slight difference in spring centerline distance between the sii and the "new" GM axle that will be going it. I believer the GM axle's spring centerline is 0.5" wider than a stock sii. I see in the kit pic that instead of bending the shackles to accomodate the differnece between the width of the frame and the width of the spring, the shackles incorporate a spacer. I don't see why I couldn't use a spacer on the upper end of the outside shackle to space it over an extra 0.25" and then use another spacer on the lower end of the inside shackle to properly position the spring.
ihpartschad
I mounted my front perches slightly outside the frame to make up for the difference, kind of like it a little wider anyway. I am thinking it should add just that much more stability. Then I just made the spacer for the shackle on the rear to fit , if that makes sence. I am really happy with the outcome. Of course I haven't had it on the road but it sure looks like it is going to ride, handle and flex good.
ihpartsjeff
Staff member
that's pretty much what I was talking about.... Would be simple enough. The other thing I'd like to address is the slight difference in spring centerline distance between the sii and the "new" GM axle that will be going it. I believer the GM axle's spring centerline is 0.5" wider than a stock sii. I see in the kit pic that instead of bending the shackles to accomodate the differnece between the width of the frame and the width of the spring, the shackles incorporate a spacer. I don't see why I couldn't use a spacer on the upper end of the outside shackle to space it over an extra 0.25" and then use another spacer on the lower end of the inside shackle to properly position the spring.
We performed this very same thing on ld's custom Scout II but I haven't posted pics of it yet. But in a nutshell both shackle plates ended up with spacers welded to them. We also used dogleg shackles since the extra length of the Chevy spring put the shackle pivot point right at the mid-front body mount. I'll try to get pics up tonight if I get a chance.
Mechanos
As usual, I waited until the last minute. I need to give you a call and discuss the exact kit I need, but I'm hopping a jet to alabama in the morning. I come back Thursday, but hopefully I will be able to get ahold of you before Friday. :out:
