I just purchased the CPT spring hanger and I have to say it is of very high quality- very pleased.
However- I instinctively want to mount the GM spring with the larger diameter bushing up front (9/16" bolt)- I think this is how the spring is intended on GM's. I could be mistaken.
So, does this bracket require you to reverse the spring and run the 7/16" bolt (smaller bushing) up front and run the larger bushing and bolt in the rear on the shackles? I just want to verify before I start cutting down my bushings and sleeves to fit in the rear- looking forward to a CPT rear hanger.
Also- have you guys played around with the different positions to see what rides and looks best? Just curious
