Hi all,
can I solicit your input on the photo below (CPT 5" front shackle kit, '77 sii, 4" suspension lift)? When I got these on, I noticed the passenger (right) side did not line up correctly b/w the frame mount and spring eye.
While the driver's side is perfect, this is where I am on the passenger side. Coming from the oem shackle set up there was no noticeable offset between them. Granted that lengthening that distance vs. Stock would make any misalignment more obvious, I honestly did not notice this prior to now.
Notice the inboard side is forced outward at the bottom, and the outboard shackle has a nice curve in it to meet the spring.
I'm wondering if the 1/2" spring spacer on this side is contributing to this?
Other side is fine and no spacer.
Spring pack is also fully seated on the center pin.
Frame spring mounts are solid and aligned front to back.
Thoughts?
Thoughts?
