Clutch for built SD33T
RMP&O
Hey guys, I think I was one of the first to buy the nv4500 adapter kit, bought mine back in 2008 or 09 when they first got produced.
I finally got all my ducks in a row for my project. My truck is actually a Nissan patrol but I am using 1986 patrol sd33t, Scout engine plate, Scout flywheel, Scout bellhousing, nv4500, atals 3spd t-case.
The engine was built awhile back. It is highly modified. Two intercoolers, shaved sump, turbo and super charged. It is not a power monster but power comes on from idle with the s/c. It has tons of torque. The truck is running 37-40" rubber on portal axles. It is a rock crawler trailer queen.
I am wondering what to do about clutch. I am not familiar with the Dana clutch I found in my donor Scout sd33t. I am familiar with japanese stuff. The Dana looks like an old school design with the three fingers. I am wanting the best clutch I can get. Is there a better clutch available for the Scout sd33t? Fully able to drill the flywheel to suit a different clutch but this Dana sucker looks a bit unique and is rather tall. Could/should I get it rebuilt for my application?
Any advice or finger pointing in the right direction would be awesome! Last piece of the puzzle I need is a new clutch. Over 5yrs in the making on this drivetrain and I am ready to complete this ordeal, just needs me a good clutch.
Oh and hey on the topic of clutch. I am going to convert mine from manual using rods to hydraulic using a slave cylinder. Seems pretty easy to me to do after looking at it awhile. But has anybody done this or better yet, got pics!? :)
cheers
FDChappie
Active member
If that flywheel is the same as a Scout it will be drilled for both 11 & 12" clutch covers. The 12" clutch is a much heavier duty item designed for the smaller loadstar trucks. I put one in my 1210 travellette last year and it is a bruiser. Now I'll put it in neutral during long lights to keep from wearing my left leg out. They will cost you around $750 though.
RMP&O
Thanks for the fast reply chappie. And that sounds just like what I want to hear! I don't know if this flywheel is drilled for a 12" clutch, can drill it easy enough though right? That is if it fits on there. Here is a pic of the flywheel I have, believe this came out of an 1980 Scout.
Dennis on the binder forum suggest I have a custom clutch built. I am ok with that too, easier to not have to do that though. I am also ok with a $500-1000 clutch, kind of expecting that in the grand scope of things anyways.
Cheers
FDChappie
Active member
That does not look like an sv flywheel. Diesel must be different. What is diameter of the worn area?
