ronbgone
I just replaced a freeze plug on my 304. She let go about 20 feet before my destination. I followed the water trail, and verified radiator was still full. So she did not over heat. The plug is the one on the front of the block right by the fuel pump. I had to remove the fuel pump to access it. After I had everything back together, I drove her home, ran great, but oil was leaking around the fuel pump. I got some rtv and pulled the fuel pump to reseal the gasket only to find the white creamy substance indicating water in the oil. Also found it on the dip stick as well as condensation drops on the dip stick. I have verified there is no oil in the water, giving me hope that I just splashed water into the oil through the fuel pump hole when I popped the freeze plug. They are only inches apart.
So the question is...how do I flush the white milky sludge from the motor? I need to verify that I do not have a water to oil leak.
