cleaning the negative connection-helped starting
int77345
Active member
Any one ever go to start their Scout, and it wont turn over and the alternator gage is pegged on d? Mine has does this a few times, more often while leaving the lights on while getting the mail in the dark. Last night I took off the negative battery cable, where it grounds to the engine block, and cleaned the cable end and the block with a wire brush. A lot of old grit came off, and it seems to have helped the cranking problem. Just passing this on, that connection is probably a good place to clean up now and then
