Justutt67
I have already done a cut and turn with SOA conversion on my stock Scout II Dana 44. I decided I wanted to use Chevy outers for the internal hub design. I got a 1976 Chevy Dana 44 small bearing off of Craig's list for a song and dance. I didn't want to just rob the outers off the Chevy and scrap the rest of the axle so I have prepped it for a cut and turn and narrow job and figure I will sell the complete Scout Dana 44 SOA ready including IH flat top knuckles for hi steer.
My question is while measuring everything 10 times for narrowing my numbers aren't adding up. If I cut 3.72" off the short side and 3.22" off the long which is the difference between the inner shaft lengths and move the spring perch center pin holes in 1/4" on both sides which is the difference between Scout width and Chevy width. My axle is offset to the driver side 1/2"! If I measure from the tube end to center pin I get about 6 1/2" on the passenger side and about 7 1/4 on the driver side. Stock measurements on the Scout are 7"ish on both sides.
It appears the differential is offset about 1/2" to the driver side on the Chevy axle vs the Scout axle. If I offset the new center pin locations in 1/2" on the passenger side and leave it where Chevy had it on the driver side it seams the axle is centered. Anyone else run into this? Am I overthinking this?
