carb choke issue
georgia scout
Hey fellas, well I have 75 Scout 2/345/Holley 2-bb ,hers my problemo. The thang been sitting for a few years and I got I running only if I wire the choke 95 percent closed. It smokes black and pops a little but runs fairly decent. Took the carb to 2 different mech. And they both rebuilt it with the same results, I have to have the choke closed of for it to run. I have all new vac lines/booster line and I have good vac. I just sent my wife to advance auto parts to get me a new Holley. I guess the old carb was just over or do yall think it is something else. I also put a new mr gasket little electric pump on it . Thanks for any in-put
First off, we need to know "which" carburetor you seem to be having issues with. In this forum you will find definitive info regarding nearly every carburetor that was used in ihc light line vehicles except for the carter thermoquad which I've not yet done, that one is in the mill right now.
And we need good pics of multiple points of the top of the engine so we can see your set up as it is currently.
I don't wanna blow out a bunch of "maybes" here without knowing exactly what you have.
If the choke has to be wired shut in order enrichen the mixture enough to run, it can't be runnin' worth shit!! And a vacuum level with the choke closed means nothing. Let's stay away from using terms such as "about", "kinda", "good vac", etc. If instrumentation is being used, we need exact numbers.
Blowing black smoke simply means an extremely "Rich" combustion chamber condition exists, again, created by having the choke plate closed in order to run.
As for the electric fuel pump you refer to marketed under the "mr. Gasket" brand name, it must be the lower pressure range version. The packaging will state the range, which iirc for the lower pressure mr. Gasket pump is 4psi>7psi. All oem-design Holley carbs are designed to use a standardized fuel inlet pressure of 5.5psi so if that is the one you have installed, it will be ok, if not, then you must use a fuel pressure regulator.
In many threads that have been started in this forum, root cause of drivability and performance issues lie in the ignition system. The ignition system must be in perfect condition overall and at each component level before dealing with any fuel-related issues.
Carburetors generally don't "wear out" but can be heavily damaged by engine bay fire, neglect (fuel deterioration), and corrosion (internal moisture contamination), and in nearly all cases, it's a combination of at least two of the three on this old junk that as been sitting. Along with heavy deterioration of the entire fuel storage and delivery system. IH stuff is no different than any other vehicle in this respect.
Most all of the "rebuilt" carburetors still available through the chain parts houses are crap, most especially anything with the "champion" label (not the same as champion spark plug brand)! I "rebuild" a "rebuilt" someone sends in nearly every week! That is exactly why ihon has available new "conversion systems" for updated carburetors that work well on some IH applications.
No doubt we can make yore rig play nice, but we must have definitive info regarding your particular set up, not someone else's or whatever "from the factory" was! Then we'll proceed in a logical progression of diagnosis, around here...shot guns are only used for bird huntin' and home defense.
Thanks for your answer. I will get more info on the carb,and some photos. I did replace all igniton,vacum lines just about everything under the hood is new. New info on the way, thanks
thanks for your answer. I will get more info on the carb,and some photos. I did replace all igniton,vacum lines just about everything under the hood is new. New info on the way, thanks
Excellent!
We can never have enuff deetale!!! The "fix" is all in the deetale!
