metalgearscout
Just swapped in good used trans. Took for voyage and all was good other than running on the hot side (220f). Was idling to warm up to add water after replacing tstat and it made a sound like a diesel and ran rough. Diesel sound continued and I hoped for something broken in the valve train. Rocker, rocker shaft, something happy like that. Pulled covers and all seems good, tight, clean. Ran it with covers off. Did pump some oil, but noise was intense. Well I have great oil pressure still, never dropped. Changed to 20w50 and was just gonna run it to the bitter end. Started it up, warmed up and ran bad hot. Vac gauge was reading way low and the needle jumped like crazy. Sound like cam bearings? The clatter is amazingly loud! Tia (I did check torque converter bolts right away, they are tight)
