C series front parking brake cable housing
seattletab
Hello,
I have a '65 travelette and I need to locate another parking brake cable housing for the front. It has a foot pedal parking brake. The housing is 59" long and clips into both the pedal assembly and a frame mount at the after end. The overall length is 75" from end of cable to end of cable, but I really just need a usable housing as I can replace the cable.
Anyone??
Cheers,
tor
I haven't had a chance yet to look at my parts rig (it's 50 miles from me) but I should be there later this week. I can't recall if it was hit with the torch or not. It was 2wd with the borg warner auto that had the ebrake drum on the trans I recall.
Thanks for your reply.
It sounds like a different set-up and likely not worth driving out to check it out. Mine is a 4x4 with the cable actuating the rear wheel drums.
Thanks for getting back to me though!
Cheers,
tor
I could have it confused with another rig I parted. I'm trying to find the pics I took of the motor and trans. I'm going anyways so I'll look. My buddy has the rear axle still so I can see if it has ebrake cables on it.
