What would be the easiest way to get the metal sleeve out of the rear part of the leaf spring?
6 64_scout New member Oct 30, 2009 #1 What would be the easiest way to get the metal sleeve out of the rear part of the leaf spring?
ronmc1954 Member Oct 30, 2009 #2 When I removed mine I first burnt the rubber out with a torch. Then I took a air chisel and just hammered it out. If you don't have an air chisel you can use a punch and chisel and peel it out. It will come. Ron
Robert Kenney Super Moderator Oct 30, 2009 #3 I've had sucess with an air hammer and the chisel bit or the flat ended bit.
6 64_scout New member Oct 30, 2009 #5 Ok that is what I have been doin I just wanted to see if there is a faster way, I dont have an air hammer though thanks for your info
