brakes on one wheel
thebyron13
I replaced allflex hoses onthe front axle also replaced the steel line from the tee on the dr. Fender to the flex hose to the tee on the axle. The right front wheel cyl. Was replaced due to leaking but all others work get with the rig in the air . The rear steel ines was also replaced due to them leaking. I also need a souce for a rear alxe hub the keyway is partly stripped out.I belive this is a 63 Scout 80 4x4 with stock axles (d27 front & d44 rear) I think
