Gentlemen ,
I have a 1963 Scout 80 with both front and rear Dana 27's . I know that the front drums are 10 inch the wheel cylinders are 1 inch. I know the rear wheel cylinders are 7/8 bore but have not measured the drum yet. The old wheel cylinders both front and rear have wagner lockheed, ( lockeed ), stamped into them.
I don't plan on replacing the axels any time soon, I have a Dana 44 out of a 67, 800 that May go into the rear in the distant future, distant.I also have a power loc out of the front Dana 27 of the same 67 800 donor rig that I will put in the front Dana 27 in the 80
I will only do light wheeling, nothing radical.
My questions are,
I have already purchased a 1974 ***p cj5 master cylinder as my upgrade, I have read on here about proportioning valves can someone please explain a little more about this to me. I want to do this right.
As another note I am replacing the entire brake system, including, new hoses, wheel cylinders, lines, and master cylinder. I have completely tore down the front outer axels cleaned and painted , installed the new wheel cylinders and hoses so far.
All suggestions and criticism welcome
thank you, jason
My questions are,
thank you, jason
