62 Scout 80,front brake drum,I cant get those four screws that seem to hold the drum on to budge.should I try heat,are they reverse thread(embarrassing moments earlier getting the tire off....)?is there another way to get it off?thanx
Just installed a new mc and lf wc,tried bleeding it with no luck,never got and fluid but the pedal did get firm.should I pull the bleeder all the way and let it gravity feed for a while?should you bleed the rear first?
As told before please keep all your related questions in one thread(discussion) as it will be easier for my tech moderators to help you. I merged your brake threads into one and moved them into the proper forum. Please keep asking your brake related questions on this thread.
