I just purchased the lower borgeson joint. And have a install question. How far are you supposed to slip the yoke over the input shaft of the box? Is the yoke supposed to grab both splines on the input shaft?
If I push the joint on the shaft too far the joint binds on the smaller portion of the input shaft. I guess the simple answer would be to not push it on the shaft so far.
