I replaced the propvalve, master and booster, front calipers and front lines with braided lines. When I go to bleed the braks the reservoir is over flowing. I do have fluid coming out at the tire too......what the heck ? When I push the pressure valve in on the new prop valve as the manual says to due while bleeding the brakes, fluid comes out........didnt have that problem bleeding the brakes prior to replacing the front calipers and lines......
