Best fan for 800 v-8...
68scout
I have a 68 800 with the v-8. I put in an aluminum radiator to help it stay cooler better and it does great at speed. But when I am tooling along slow in the hills, especially after a hard run to get to the hills, or if I shut it down I can hear the coolant boiling in the heater core. I have the five bladed fan. Can I put a clutch fan on my scout? I would be simple enough but for the lack of space between the front of the water pump and the radiator is only about 2 1/2 inches? The six bladed fan would cool great especially when it only engages when it gets hot enough.
68scout
Cool! I do not know the dimensions under the hood of a scout two, but I'm pretty sure they were made to work with the V-8 engines, unlike the 800. Yesterday, before things got really hot outside I made a drive up 6 or 7 miles at a 10-12 percent grade. the engine temp was never an issue. I thank the five bladed fan and the aluminum radiator. It works great when you can get a bit of wind through the system. But, in the past, late August and crawlin around at low speed or just stop and idle the gauge tops out and I hear boiling in my heater core. I guess that I will do some looking at the different fan clutches and see if they make and that are short enough to fit in my tight engine compartment, or a shorter water pump hub or anything like that. I had a mechanic friend recomend that I go with electric fans but I have heard debatable reviews on those. Or there is always the option of a flex fax but would the benefit of those outway hassle?
