Hi, I plan to install a cable-driven tachometer. I have a Delco distributor with the cable drive option for my 392 V8. There are two different types of cable-driven tachs available from Isspro. I noticed for every full revolution of the distributor's rotor the distributor's cable drive would make one full revolution. Isspro's tech support could not tell me which tachometer to use. One version states .5:1 ratio and the other version is 1:1 ratio. I'm not clear - does .5:1 mean that the tach shows half the rpm's or shows double the rpm's because it expects to see the drive to spin at half the rotation speed of the rotor? I'm so confused I don't even know how to ask the question properly, especially taking into consideration the rotation of the crank in relation to the distributor. Which version of tachometer should I use and why?
Thank you.
Thank you.
