Good ta hear from ya Bob the door man!!!!
A new 2300 witha a warped throttle body??? No way!!!!
Do you mean..."new to you"??
The mounting ears will break off long before the throttle body will warp when either tightened down incorrectly, or the wrong gasket/spacer stack is used inna non-stock setup.
If it'sa list 7448 center hung, then a new throttle body is an easy item to purchase. If it's a 2300 oem (side hung float bowl), then most of those are also available new, and we have quite a few nice used ones, I ship one about every week once I've cleaned and inspected. There are many variations though, the throttle body must match the list for the carb in question.
The number one secret to making Holley modular carbs play nice...is to tighten those throttle body screws to a point just under strippage...after applying some loctite "blue". And if it ever needs to come apart again, then the screws will come out real nice if the proper phillips tip is used as you mentioned.
And if by some kinda freak occurance the manifold side of the throttle body is out of plane, then that's easy to correct using machine shop services or what I do...a "redneck mill" job...and surface it onna belt grinder/sander. Doing that is part of all carb overhauls I do on those units, makes 'em look real purdy!
