Ball joint and Wheel Bearing Advice 1977 scout II
int77345
1977 scout II 345 4 inch lift 33 inch tires
with my furlough time i decided to pack the wheel bearings. what do you all think is to tight for a front wheel bearing. i did as the IH manual says spin the wheel and torque to 30ft pounds then back off 1/4 of a turn. doing that the nut was only finger tight, seemed to loose to me, so i snugged it just past being finger tight. on the IR temp gun the hubs are running at 110-115 degrees that seems ok right ?
i also noticed the upper ball joint on the driver side has just a little bit of side to side play in it. maybe 5mm give or take, translates to the slightest wiggle at the tire when sitting on the jack stand . is this something to be concerned with ? or let it go till there is a lot more play at the tire . ?
If there is play in the BJ change it. It's only going to get worse.
There should be two nuts for the wheel bearing. One to set the preload and one to retain the first nut with a locking tab that is bent over the edge of the outer nut.
Hondo
Always hated those bend over tabs, just don't like hammering on some things. Stage 8 makes some very nice locking spindle nut stuff p/n DNA-44, you can google them. Kind of pricey for stingy IH people, but very high quality made in USA stuff that make the job much easier, and won't come loose.
