stu simpson
I'm not waking anyone up in the brake forum so maybe I'll have some luck in this one. I am trying to finagle some useable front brakes for a 2wd Scout 800 and have been struggling a little with the stock beam axle(category #1). I have several donor axles on hand, and some coming, in order to manufacture operating drum brakes for the little rig. It is a 1966/67 Scout 800 lhd 2wd sportop convertible with the small 4 lug pattern. The front drums are split, supposedly a common problem with the 4 lug, and the rear axle is out of a falcon according to the po. So they are coming out asap. I have a lhd 5 on 4.5" set with 9" x 2" front brakes on hand and will use these probably if I can't make category #2 work. The axle is missing a hub and drum and the condition of the other hub/drum is not great. The rear axle is a powrlok'd two-piece model in 5 on 4.5". One of the donor front axles is out of a mid 60s rhd 800 postal and has good hubs/drums equipped with 10" front brakes. Also comes with a set of 5 16" 5 on 4.5" rims. I do not have any microfiche for any 5 lug front axle setups, only the 4 lug, even though the 5 lug was produced prior to the 1968 or so publication of my (complete) fiche set
So that brings me to this forum. I am considering using a sii 2wd tube axle and narrow it, giving me disc fronts and allowing me to use a flanged d44 rear out of a Scout 800. Then, I can also do a rear disc swap and use 5 on 5.5" Scout II wheels, or 16" 5 on 5.5" Scout 80/800 wheels with spacers.
How deep is the tube pressed into the c? I figure I only need to do one side, then relocate the perches and fabricate a custom tie rod/drag link set out of dom. This can't be any different than the opening sequence of a cut/turn, right? Grind out the welds, knock off the c, chop tube, jig it up/reweld. Iirc, the tube is a blank d30? How much caster is in a sii 2wd axle? Does it depend on the year of the sii it was removed from?
For that matter, does anyone know the caster specs of a Scout 800 2wd front axle???????? Does it depend on 80 or 800 or 80/800/late 800 2wd????? There seems to be parts variation between the early 2wd (beam) 800 axles and the 69-71 2wd (beam) axles, maybe there are different setup specs too?????
