WRECKTHOSECARS
I have a pinion angle question. I need to know the perfered front and rear pinion angles for my project. It is a 75 Scout II. I bought 4in springs and shackle reversal from IH only. The reversal is installed is per the instruction. Current angles are as follows: front is 2.5 degrees down and the rear is 4 degrees up. I have not installed any shims but the front steering linkage (that connects the spindles) is rubbing on the springs. I am affraid that if I install caster shims, in order to correct this problem, then the pinion angle will be even worse. I am curious about the proper caster angle at the knuckle as well. My plans for this vehicle is mostly a daily driver, but for it to be capible of road as well. He is my forum post http://www.forums.IHPartsAmerica.com/readers-rides/737-hemi-Scout.html
