Are all Yokes created equal?
Or do some of the yokes for a Dana 300 transfer case allow a larger angle without binding?
The ones pictured on the IH only site appear to be a little different than mine.
Some of the yokes we carry are a little "deeper" than the stock ones thus allowing for more angle. It really depends on the yoke as some are and some are not. Depending on which yoke you were looking at it May look different as it May be for a cv type driveshaft.
Hi Jeff,
do you have a yoke for the Dana 300/1310 u joint/ stock drie-shaft that allows bigger angles than stock?
With Skyjacker 2" lift, my caster is -3. Looking to get it to 0 or better.
I jacked her up and looked at the front drive-shaft yokes with the suspension hanging. There is very little clearance at the t case yoke now, so I could be in trouble with caster shims.
Sorry to take so long to get back to you. It appears the 1310 yoke that we sell is approximately .125 taller than a stock yoke. Visually looking at it there is certainly more room for bigger angles than the stock yoke.
