capt jake
Its a 78 Scout II with the 345 auto trans. Rear drums bleed normally. Front disc brakes blow air from bleed screw and some fluid. There are no fluid leaks from anywhere in the front system that I can see. The pedal starts hard and then softens to the floor until the rears engage and the "brake" light illuminates. Pumping the pedal restores pressure to the front. Cannot find the leak. What puzzles me is that I do not lose fluid in the front reservoir unless I bleed them. Bottom line is I cannot see where I am taking in air. Troubleshooting recommendations and parts list if able. I dont want to just start throwing money at the problem. Thanks.
Jake
Jake
