Advice on cut and turn
Mschroeder1991
1975 IH Scout 4x4, dana 44 front
Installed 4” rough country lift with stock shackles.
Ive been reading it will be smart to do a cut and turn now with the axle being gutted for new seals. As it sits it is just the frame with the body off. So its hard to gauge what angle is needed when i do the cut and turn without having any weight on the frame and the springs not compressed. Anyone have some advice? Im guessing ill also use 4 degree shims for pinion angle?
