AC Upgrade - Shop Manual Question
pplaut
@Zaedster - I am completing what I think to make the AC stuff work.
The shop manual shows an additional pully attached to the water pump. Making three across.
Would this then be three across the bottom too?
Two for the alternator, one for power steering and one for AC.
^^ Does this make sense?
If this is the case, do you have the extra pullies I need?
Thanks!
~P.
@Zaedster thanks - Do I need three on top and three on the bottom, or two bottom and three on top?
I also need a two pully adapter for my alternator.
I will call you next week.
Have a great Thanksgiving.
~P.
@Zaedster
The first item is for the water pump pulley
https://www.ihpartsamerica.com/store/CPT-ADP-4-W.html
This is for the AC Unit
I need a generic 2 pully alternator pully to replace the single I have
Also, it would seem I need a 3 pully now instead of a two pully on the crankshaft.
Also, what belts would I need?
Thanks!
~P
You can upgrade to dual if you want. The A/C compressor only uses one slot in the pulley.
