80/800 hydraulic clutch pedal
I have looked up pictures and found a 80 pedal assembly and the clutch pedal is mounted closer to the brake pedal and the master cylinder is connected to it . The 800 v8 clutch pedal is mounted further away and I cannot mount the master cylinder to a flat surface. My pedal is a cable pull type which pulls from above the brake master cylinder. I will try and find the pic that I saw
