MightyMonte88
Hey guys I need some help. I started doing a tune up on a friends 1979 Scout 2, 345, manual. This thing was pretty neglected so it needed a full tune up and go over. So far I've replaced plugs, wires, cap/ rotor, pcv valve and all vacuum hoses, except the hose that travels from the air cleaner to the driver side valve cover ( pickup for crankcase vent right? ). Had to grab a new air cleaner assembly, just went with what was recommended for the edelbrock. Aside from that everything else was standard, fluids and seals.
The original thermoquad was done for, the resin body was cracked. So after doing some homework I found that an edelbrock 1406 seems to work pretty well with a stock IH 345 in a Scout so that's what I went with, out of the box set it up to edlebrocks calibration 19, allot people claimed they had really good results with that calibration.
The problem is, as soon as we fire the engine it wants to rev up high unless I keep the choke closed by hand. This is where we stopped, ran out of daylight to diagnose any further, so I figured I'd post up all the variables on here and see if yall can spot something I missed. Any help would be appreciated.
Had my vacuum gauge on while we ran her, it gave a very steady reading, but it was low. I suspect a vacuum leak? One thing that slipped my mind was the hose I mentioned above, the one that travels from driverside valve cover to air cleaner, I didn't have it hooked up to anything. Will this cause a vacuum leak?
Also, I tried hooking up the distributors advance to both ported / manifold sources of vacuum on the carb. The reason I tried both is because the emissions system was deleted by a previous owner, I'm not sure if the distributor is curved / setup for emissions still.
Sorry for the novel, this thing is a special case haha
btw, engine did not do this before tune up. It just ran like hell due to lack of maintenance / carb was leaking pretty bad. And even after warming up, if you open the choke she revs up.
