scoutpappa
I did a little work a few weeks back on the back drums of a 79 Scout II with 11 1/4" drums to get the parking brake set. After tinkering and lubing and verifying action of the system I had to bleed the drums to get the drum itself back on. In doing this I naturally keep an eye on the backs just in case something is leaking. So once a week I check the mc and climb under the back to verify that nothing is wet. So what I am seeing is that the back portion of the mc is loosing an 1/8" of an inch of fluid every three weeks. Back drums are dry but it appears that the booster is leaking brake fluid. The m/c itself almost looks to be "sweating" fluid. Brakes work well (for a Scout). No noticable lack of performance but brake fluid is not the best thing to have leaking (taking what's left of the paint off of the booster). So is there a gasket or o/ring that keeps the fluid out of the booster that I need to change and now that this appears to be what is happening do I need to worry that the booster internal (diaphram) is going to go out?
