77 Scout + Kwik Wire 14 circuit harness
Pensacola Scout
Gents, I am installing kw14 harness in my 77 Scout. So far so good but will have a few questions for you smart dudes.
Vehicle: 77 Scout 345v8, 727 auto, chassis # 66022410
First question: nss.
1. I have the schematic and it shows the 3 pin transmission switch wired as follows: left pin-power from old fuse panel / center pin-to nss relay/right pin-backup lights.
2. K/w 14 doesn't indicate where the left pin gets its power. Needs some advice......
3. I think the nss relay wiring is as follows: top pin-to ignition block. Bottom left pin-nss wire from starter. Bottom right pin-nss switch center pin.
All help is welcomed!
Coming from the neutral safety / back-up lights switch from the transmission should go yellow is backup lights, green is neutral safety, and red is power in. The harness has a wire to hook to power (red) and a wire to hook to neutral safety (green) and you hook yellow to your tail harness for backup lights. The wires in the harness should labeled what they are but I can't remember what color that they are.
