74 3/4 ton pickup project
Newguy1
Hi, I’m new to the forum scene, this is my first time actually posting in a forum for questions - so hopefully I put this in the right category. Please correct me if I’m wrong.
my project
What I know (which is not much): it’s a 1974 travelall 200 with a 392 v8. It’s been sitting for 16 years with the passenger side valve cover off
My plan: I don’t want this thing to be pristine. I want to put it to work for hauling heavy stuff. Now I am new to these internationals as this truck was given to me. I have a flat bed to put on it when it’s running again and if we don’t think this engine is any good I have access to a fresh 392 block, but I’ve heard these motors are bullet proof so I really want to get this motor on a stand and see how bad it actually is. Before doing so I’m going to remove the heads, spray down the cylinders with marvel mystery oil and let it soak before I try to turn it to get to the converter bolts to pull unless suggested otherwise.
What I’ve done so far: I’ve removed the front clip, brake booster, heater box, wiring harness, etc. to get the motor exposed as much as possible and have been vacuuming with a small tube to get as much dirt out of the open valves as much as I can. I’ve removed the carb and thermostat housing and I’m ready to pull the intake. Right now I’m searching through these forums to find the torque sequence of the intake. I know I have to go in a crosshatch pattern, but I’m unsure if I go outside to in or inside to out and reverse it when I put it back in? Also I’m looking for a detailed description of removing the heads on this thing as I’ve never done it before but as you can see I’ve got nothing to lose. Lol
Sorry for the long post for a couple questions. just wanted to give you guys as much info as I can, because I’m sure many questions are yet to come.
Newguy1
I went inside to out in a cross hatch pattern to remove the intake now I’m researching head removal. I know I need to keep everything in order to the T, remove the rocker arms, and push rods. I’m assuming I remove the head bolts in a crosshatch pattern working inside to out can anyone shed some light on this? Also my dad told me that not all motors will need a spring compresser to remove the keepers for the push rods. Is that the case or should I weld something up or buy something to compress the springs? Thanks again!
Zaedster
Future Owner of IH Parts America
Yes, you need to remove the head bolts in a particular pattern to prevent head warping. Seeing that your user name is "Newguy1", you would probably most definitely benefit from a service manual, as it has all the proper procedures on how to do any sort of service activity on the unit. https://www.ihpartsamerica.com/store/SLCTS-2303.html
For the spring compressor, I'm sure your Dad is right. You may not need a valve spring compressor in a Briggs and Stratton 2.5 H.P as the spring rate is way reduced compared to a full-size engine. Understanding that your head is going to be removed from the engine block, this compressor would be a good option: https://www.summitracing.com/parts/...tWUTREEmLRingzxHkEeocqVbSgMeL3joaAiNbEALw_wcB
As with any used engine disassembly and reassembly, all parts and pieces must go exactly where they came from.
Newguy1
Thanks for the info
Welcome to the forum. Just FYI, the Travelall is a full length wagon-style vehicle very similar to the Chevy/GMC Suburban. What you have is a 3/4 ton pickup, which IH designated as a 200 in model year 1974.
Newguy1
Thank you guys for all the feed back. I’m still doing a bunch of research while I’m working on this thing so far I have the top end of the motor off I’ve soaked everything in oil and with the heads off I primed it (knowing I’ll have to do it again once put back together) the motor turned over smoothly while priming. Now before I put this back together can anyone shed some light on the improved cooling system I’m hearing about and How to identify if my block is a improved cooling block?
I’ll get some better pics if you need more to go off of.
1975IH200
IHC SV-8 392 - Improved Cooling engine:
The water tubes enter the BLOCK on the IC engine.
The water tubes enter the HEADS on the Non-IC engine.
Head gaskets are different and specific for each: IC and Non-IC.
Cylinder heads are different and specific for each: IC and Non-IC.
Only the 392 has the Improved Cooling, 266, 304 & 345 engines do not have improved cooling.
There is a sticky thread in the 'Gas Engine Tech' Forum on this subject.
Your engine is an Improved Cooling engine due to the location of the water tubes.
