74 200 pickup
74 200 2wd pick up fleetside with shell. Coil spring,a arm front suspension with discs. Dana 60 rear, 8 bolt rims, 345, t19 fully sinchronized close ratio four speed. Currently running on propane with 100 gal tank in bed. Engine very clean. Good brakes. Runs well. Colorad orange and white.
Needs tires. All the usual rust spots on the late bodies. Windshield has a crack.
Easy conversion to gasoline: tank, fuel pump and carb.
$1500. Located in n. CA. Doc stewart dfsdc@pacbell.net 650 245 1199 eves and weekends.
