73 Scout -$5500obo
73 International Scout II. Built for trails,rock crawling,mud...and very streetable. All parts less than 1 year old. 345 v8: new Holley two barrel setup for offroad use, new electronic distributor setup with 50,000 volt coil,plugs and wires.100 amp alternator, dual exhaust with thrush welded mufflers. 727 auto, Dana 20 case. Fully rebuilt driveshafts. Front axle: narrowed 3/4 ton Chevy 44,flat top knuckles have been cut/turned with blue torch fab high steer arms and studs, redrilled outers for Scout disc brakes, new mile marker supreme hubs, 4.56 gears with ausie locker,all new u joints and bearings/seals. Extra set of front axles shafts included.cross over high steer with chromoly heims,psc hydro assist ram, new psc gear box, rancho springs,CPT shackle reversal and spring over kit, 5/8 u-bolts thru custom 3/4"thick plates,procomp 12" travel comp shocks.daystar 4" poly bumpstops.rear axle: Scout Dana 44, all new bearings/seals, 4.56 gears,ausie locker, rear disc brakes conversion, ballastic fab cover,5/8 u-bolts, 3/4' plates, rancho springs. New poly gas tank,fuel pump lines and two filters. Wheels are new custom 15x10 steel beadlocks- 32 bolt all stainless hardware, powder coated rings, tires brand new pitbull rocker radials- 37x12.5". Bumpers are custom, winch is 9,000 pound.cage is 1 3/4", tied to frame/rock sliders. Brand new corbeau suspension seats and sparco 4 point harness, Scout rear bench. Grant steering wheel. New winshield. All other glass good. Floor has been patched...no holes looks great. All lights, wipers,horn work. Some gauges and speedo do not. Have original steel hardtop- is black and in good shape. This is not a show vehicle, restored Scout, or a daily driver.if that is what you are looking for look somewhere else. It has been built to wheel hard, and has a few scars to show it. Asking $5,500. I would be interested in a trade for a newer 500 or up 4x4 quad . No junk wanted, I have enough of my own. Email at predatorhunter76@yahoo.com For more info or pictures. Can call or text at 309-2/0/2/- 3154. Located just south of peoria, il
