scoutpappa
So been on a buying spree at IH north. What is the trick to getting the cable holder loose that is located by the transmission. I have the shifted out and the access plate removed. The original cable is disconnected and all I lack is to get the holder closest to the transmission loosened. It appears that the entire bracket can be removed to gain access to the two flathead machine screws. Is this the correct path forward?
