Buck Dodson
So,
I have a sii 727 with a d-20 in this 800
Not quite all stock and biased toward trail use, but it is driven to the trails, not trailered. When I did the swap from the bw-11 tranny, I put in a rebuilt tranny. I toasted the 727 while wheeling. The rebuilder rebuilt it again, and said I needed a better cooler because several items were "fused" in the tranny.
I am running a stock 800 radiator which has no provision for an automatic. My cooling is from an aftermarket cooler mounted in front of the radiator and a combination of rigid and tranny rated flex lines for the tranny to cool connection.
1. Since the cooler is a continous flow through, it shouldn't matter which line (pressure line or return line) is connected on the cooler, correct?
2 should I be consider a radiator swap to something with a built in cooler and perhaps still run the aux cooler?
I'm in the process of pulling the tranny again due to another issue, but I would sure like to put a tranny in and leave it for a while, so I would really like to eliminate the cooling issues from the discussion...
Btw, the stock radiator is cooling the 345 without problems, and I'm not afraid of modifications
