72 Scout II Liquid Vapor Separator
Good Day,
I have an after market 30gal fuel tank that only has the 2 rear vapor vent lines and the drain back and I'm trying to make sure I connect them properly to the Liquid vapor separator. I've looked at the evaportive loss diagram but can't really tell where I should connect the lines and block off the others.
As best I can read it, the last vent port goes to the top of liquid.vapor separator toward the tailgate side of the truck. The next vent Line goes into the first port closest to the tailgate and the drain back connects to the next shortest tube. The remain tubes get capped off.
Let me know if this correct or please direct me to the proper connections.
Thanks in Advance.
Sam
