72 3/4 Ton Longbed 4x4
Selling 72 3/4 ton longbed 4x4 I bought this truck from a friend for use as a fishing truck but have not had the time to do anything with it. The engine is either a 290 or 390 v8 whichever one is the original engine for these trucks. The engine runs but the truck needs a front bearing replaced before it can be driven. It has a manual transmission, and body has some dings on it but nothing major. The truck is located in lodi California at my friends house and I do not have any pictures of it but viewing can be arainged. Registration is 1 year out, but have clean title. I would like to get the $400 I paid for it but might consider reasonable offer. If interested or have any questions e-mail me at jmlim@comcast.net And I'll get back to you. Thanks for your interest. Ok I finally was able to take some pictures of the truck, I didn't have much room to take the pictures so the shot's aren't the best.
Additional Info
Sorry for this poor ad placement but this is the first time for me. Fortunately I received a e-mail showing how unclear and insufficient my information was which is the purpose of this post. The mailing inquired about the bearing problem which needed much more clarification about the specific condition and description. The front wheel bearing and hub need replacing before it can be driven. When the bearing problem was discovered it was parked in his garage then shortly after I purchased it. The front drive assembly is not original but are from a GM 3/4 ton truck. The wheel bearing and hub problem is what prevents this truck from being drivable. The engine can be started and run and the manual transmission and transfer case both worked with no shifting problems in 2wd or 4wd. The engine is a 392 v8 and if I remember right has a 4 barrel carb on it, the truck does suck up some gas. It also has power steering which broke a belt last time I rode in it but has since been replaced. The truck has what I call patches or areas of what I refer to as surface rust, meaning it can be sanded off, but are not too bad. The interior is original and from my recollection has some age cracking and a few small tears here and there is in pretty good shape. The front windshield does have a crack in it, but the other glass is fine. From my knowledge it had a problem with the brake hydrolics but was fixed prior to being parked, unknown about condition of brake pads. I'm including the phone number 209-465-3110 for additional information or make arraingments for viewing truck. My name is jerry and if I'm not there leave a callback number and I'll return your call. I feel the $400 was and is a good price for this truck but because I would like to sell it asap I might be open to reasonable offers. Thanks for the interest.
