71' 800 CPT Crawler Lift Kit - Specs
IH800_GreyDuck
Hello-
The PPO installed the CPT Crawler kit (awesome) (Dana 44 rear, 30 front. V8)
The PPO also bent the front of the frame (not awesome).
The passenger side front frame is 1.125" lower than the drivers side. Checked the diagonals and doesn't measure out to be out of whack.
I have the spec book for the 800 but it give the height of the front of the frame stock.
Anyone have the floor to top of the frame height on a 800 with the same specs as mine?
Looks to me like that new front cross member was not welded in properly and that is likely where the frame has twisted.
Pull the axle out, put stands under the frame sides and cut that cross member out and get a proper one welded back in.
