tee jay
I need to swap cabs from a 75 pickup 4x4 to a 73 pickup 4x4. The 69-73 cabs had only one cab mount on each side at the front and the 74-75 had two mounts on each side at the front. I dont visually see any difference between them. The 73 cab that I am removing have dummy bolts in the holes where the double cab mount would be and the cab mount brackets that are rivited to the frame are shorter because there is no mount there. Just wanted to make sure this will work before I go through the hassle of taking the cabs off?
