69 Travelall D1100 4WD for sale
69moby
Greetings
I have a 1969 Travelall D1100 4WD for sale. It was my desert truck that turned into money pit.
I have had the engine (in work forget which engine but not the 492) Been thru the brakes and most of the electrical system. I added TB fuel injection.
Hoping for $3k
Pictures forthcoming
Needs:
Battery
Tires
fuel pump
rear window motor
a new home
I am in the SoCal area
69moby
For the most part the body is good. There is some rust through by there rear gate. There is some surface rust, but I was running it in the desert, so I never addressed it.
69moby
What fuel injection did you put on it? Did it ever run with it? What was done to the engine? Manual or automatic?
I used the "Affordable (throttle body) FI kit. I ran fine, I was able to take it camping with no problems. Has ~1000 miles (maybe less)
The Engine had a full rebuild. While sitting water got into the engine and seized it. New pistons/rings... all the bearings (rod/crank/cam). While there I had the heads done also (valves/springs/guides)
It has an automatic trans.
