67 Pickup stepside 1200 2wd parts Santa Cruz, California
RustyRide
Dismantling my truck. Keeping some stuff but the following is available.Local pickup only
Steering column $45
Front bumper (bent on pass.side)$15
Rear window glass $35
Cab shell $50......GONE
Doors $45 each
Front outer fenders(need work) $20 each
Rear fenders $60 each
Driverside step(long bed) $50
Passenger step(long bed,has some xtra holes drilled in it) $40
T-98 transmission $125......SOLD
Driveline $50
Rear axle $100
Front axle $85
Oil bath air filter $15
Big 6 pattern split rims(2 available) $20 each
Dash assembly(gauges,glovebox door,etc. Cardboard glovebox didn't survive) $100
Hydraulic dump setup made by aristocrat. Runs from PTO off the transmission. $250
Hydraulic dump and transmission are sold.
If anybody is interested in the cab please let me know ASAP.
I will be taking it off the frame this week. Removing glass,door, hinges,seat belts, etc. If someone wants the cab I will be more gentle with ( like not cutting the sheet metal around the hinges with an angle grinder). Otherwise it will probably get recycled next week.:(
Thanks. On the driver side fender, I've got really bad rust where it meets the stepside. How is that area on yours?
Mike
Driver side rear fender. Here are some photos of the area you asked about. Sorry for the delay in my response.
It looks a lot better than mine. I see the crease in the back, are there any other dents? You May or May not know the answer to this, but my truck is the '73 D body. I've heard, and it definitely looks it, that the fenders are the same from the early 60's to end of production in '75. If anybody knows the answer to this it would be most appreciated. Where in Santa Cruz are you?
There is some damage to the rear bottom edge(see photos below)
Not sure if it will fit those later years into the 70's. I'll try to find out.
Truck is located in Ben Lomond which is about 10 miles north of Santa Cruz. I can bring the fender down to Santa Cruz if that's more convenient.
Sorry, got sidetracked there ... Anyway, I'm still interested. I'm trying to figure out a time I can get out to Santa Cruz ... I'd like to shoot for this weekend, but that might be falling apart. I'll let you know.
Front axle $85
Front big 6 drums $35 each
Driveline $50
Dana 60 rear end with big 6 lug pattern drums $100
Located near Santa Cruz, CA
