'67 International 1200 B
I just don't have the time nor money to put into this truck, so instead of letting it sit as is, I'm putting it up for sale. Here's some details about it:
-1967 International 1200b camper special
-original 304 v-8 never been apart to my knowledge
-4 speed manual with granny low and floor shifter
-heavy duty rear axle with 4.10 gears and locker
-truck is 2wd
-long bed, standard cab
-my grandfather is the original owner (whoever buys this truck will be listed as the second owner, I've not transferred the title)
-truck has fairly new tires, probably has around 100 miles on them
-brakes need attention, front needs to be rebuilt
-carb was rebuilt, but fuel pump has gone out
-converted to pertronix ign, still have original points stuff (the original dist is still in the truck)
-it still has the oil bath air cleaner assembly
-has the factory exh manifolds, pass side replaced due to old one cracked, still have it though
-truck is white exterior with tan deluxe interior
-truck has original ac that works last time tried, manual steering, and power brakes (new master cylinder)
-the slave cylinder and clutch master cylinder have also been replaced
this truck is for the most part original, I wanted to restore it, but I just don't have the resources to make it happen, so please, someone save this truck.
I am just north of albany ga, buyer will have to pick the truck up, or arrange for delivery. I am asking $3500 obo. The truck does not run currently due to the fuel pump, but was running great after I converted to the electronic ign just before the fuel pump went out. Transmission does great, and the suspension is solid. Just needs a resto. Pictures possibly available upon request, but please, serious inquiries only.
Thank you for your time,
justin
