67 international 1100B ignition switch
Android2887
I have a 67 international pickup that started just fine when I received it. now the ignition switch does not work. it will start and run if I jump the starter solenoid. I replaced the switch, the coil and the starter but it still only starts if I jump the solenoid. Any thoughts???
Karl1968
Probably a bad wire down to starter from the ignition switch or maybe corrosion. quick and easy to run a new wire from the switch to the starter
