66 Pickup Brake questions... Using 67 system.
So I have an old 67 that I am parting out. I want to use the brake configuration in a 66 pickup so I have the dual master cylinder, and a separate master for the clutch.
I was wondering if anyone has done this and if I need to pull anything else besides the plate behind the cylinders.
Might verify the distance between the push rods for the clutch and brakes. The earlier 'siamese' system May be closer together than that used for the later individual cyls? If the pushrods are too close to align with the later plumbing, you May have to consider swapping over the later pedal assembly.
Bill bennett 68 Travelall
