66 404 V8 - EFI and Electronic Ignition Upgrade
Jeff- thanks. Let me get this bad boy back on the frame, make sure it runs again and then I will order this. Probably be mid Sep since the frame is still in for paint - hopefully next week. :) Thanks again to help me make this a looks like it rolled off the factory floor Travelall restoration with modern upgrades. I don't like the term restomod as this usually refers to, IMO, hot rods. :)
I am going to continue to use the 2 fuel tank system. Which, usually means the mechanical pump needs to be replaced with an electric pump. Since most of these electric pumps are pusher pumps up from the tank, do I need two electric pumps. Or, is there a single electric sucker pump that will work? Thanks!
~P.
Jeff-
Thanks for this. I'm a little way out. Before I pull the trigger on this, I will get the full parts list. :)
I have the sending units.
~P.
