I have a 2wd 64 c1100 pickup with a 3-speed column shifter. The shifter linkage parts in the steering column have too much play and it sometimes gets stuck in gear. Are there parts available to fix this? Thanks,
anthony
I did some research in the service manual and it showed making an adjustment to the play in the linkage parts for the column shifter by adjusting the position of a nylon bushing. I made this adjustment but it was almost maxed out as it was and one of the set screws that holds it in place was stripped. Is this nylon bushing an available part? This truck has a t-4 transmission.
