62 scout 80?
NONYAMT
It has dual tanks im assuming with 2 fuel caps,do these tanks feed into one line or s there a valve to switch tanks?
Should be a valve on the floor, drivers side, that switches between the tanks. And there should be a toggle switch on the dash that changes the tank the fuel guage shows.
Ok found the valve under the drivers seat,I guess the pointer opposite the handle points to the side of the vehicle you are drawing fuel from,no switch on the dash though...
